Ana içeriğe geç
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
20 Soru Tümünü görüntüle
New ifixit battery only charges to 7%
Just replaced old battery with new ifixit battery I bought through your website.When I turned on laptop after installing “new” battery, it showed charge at 56%. I used computer until total discharge then plugged charger in. After 2 days of being plugged in, it only charges to 7%
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @domingo28098 did you follow the battery calibration instructions?
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
I would try this calibration method and if it does not work, the battery has a 1-Year warranty
This product is guaranteed to function for one year following the date of original purchase. The guarantee period begins on the date the original order is placed, not the date the product was installed or used.
Of course, you can always contact iFixit support. Best of luck!
Replace a 8700 mAh battery compatible with MacBook Pro 15" Retina (Late 2013/Mid 2014). 98 Watt Hours (Wh), 11.26 Volts (V). Görseli
Ürün
MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery
$89.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Domingo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 60
