How to take apart and clean lint that's inside dryer
My ge electric dryer 6.2cu ft has tons of lint inside model number GTX33EASKWW HOW TO TAKE APART AND CLEAN ALL THE LINT OUT
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Unfortunately I couldn't find any information specific to your dryer, but the PartSelect website has general instructions for opening the cabinet of a GE dryer that should help you figure out how to get yours open so you can vacuum out the lint inside.
How To Open The Cabinet Of GE Dryers
Here's their instructions.
== How to open the cabinet of GE brand dryers : ==
Opening the cabinet of GE dryer models
Note: Disconnect the power source to your dryer before you begin to open its cabinet. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. Removing the inspection plate will allow you access to the dryer's rear drum bearing.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 8
Son 7 gün: 48
Son 30 gün: 230
Her zaman: 12,128
