Ana içeriğe geç
iPhone 13 için tamir kılavuzları, el kitapları ve sorun giderme yardımı. iPhone 13 cihazınızı kendiniz tamir etmek için ihtiyacınız olan her şeyi edinin.
Charging port won't work
my charging port will not work anymore. i have tried cleaning it our with compressed air and it still will not work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Slade,
Assuming you've already tried a different charger and cable, then you're pretty much down to having to replace the charging port. It's not at all uncommon for the pins inside to get bent or damaged causing the port to fail. The repair itself is fairly straight-forward for an iPhone. Unfortunately iFixit hasn't gotten a chance to create that guide yet, but the Spanish site Nadie Me Llama Gallina has just what you need.
Manuals / Apple iPhone 13 / Charging flex
You can buy a good quality replacement part right here on iFixit though. It comes in various colors so the inside of the port matches your phone case, although in practice any color will work; it's strictly cosmetic.
iPhone 13 Lightning Connector Assembly
Don't forget to pick up a sheet of precut adhesive to glue the screen back on when you're done! I usually get a couple - they're easy to mess up and very unforgiving so it's a good idea to have a spare on hand just in case.
Good luck; let us know how it goes!
Replace a lightning connector assembly compatible with an iPhone 13. Includes the flex cable, logic board connector, lightning connector socket, and two microphones. Part #821-03154. Görseli
Ürün
$49.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Slade Martin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 116
Her zaman: 1,830
