Ana içeriğe geç
Power issue: Runs with battery only. DC in Replaced. What else?
Laptop runs fine with the battery, alone. NOTE: I just replaced the DC-in board with no improvement.
As soon as I plug in the AC Adapter, it immediately shuts-down. The indicator light at the DC-in plug doesn't light up at all (ever). I have 3 AC adapters, and it's the same with all of them.
I just replaced the DC-in Board, and the problem is exactly the same. Unless the replacement is also bad, I am at a loss as to what it might be.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
Thanks for the quick feedback.
- Confirmed all my AC Adapters are 65w.
-Confirmed AC Adapters work on my GF machine.
- With the new DC-in,the problem is exactly the same. (I'll ask for a swap for another one).
- I tried to rest the PMU (per your instructions), and machine did nothing (no lights/sounds, just dead) (no light at end of the plug, either)
NOTE: If I boot with battery only, and plug in the AC Adapter, the machine IMMEDIATELY shuts off.
tarafından
Yorum Ekle
Apple Watch Kitleri
Screen and battery repairs just got easier.
Hemen Alışveriş Yapın
Apple Watch Kitleri
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try to find a tech that will take a voltage measure at the output of the DC in board using a multimeter then you'd know if the logic board is getting power. If so then the logic board would be the culprit.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
Are your AC adapters all 65-watt? 15" PowerBooks will not even power on with 45W AC adapters.
Is the behavior with the new DC-in exactly the same as it was with the previous DC-in, or is it behaving differently? Do you know for sure that the new DC-in is good, and did you buy it from somewhere that is guaranteeing it and will swap it out?
I would remove the battery, connect the AC, and try to reset the PMU by holding the power button in for 10 seconds until you (hopefully) hear a tone and see the sleep light blink.
Assuming the power adapters are good, and the memory is good and firmly seated, I really can't think of anything it could be besides the DC-in or the logic board itself. Again assuming the AC adapters are good and 65W, it is odd that you don't get a light on the DC-in, and that may indicate that the DC-in connections to the logic board are not in place or fully seated.
If that's not the problem, I would swap the DC-in for a known-good one and try again, and also test your AC adapters on another machine so that you know for sure they are working. I know that sounds silly, but when troubleshooting it's 100% critical to know for sure that components are working, and making assumptions, no matter how good they seem to be, always causes problems. (For instance, maybe your computer or a flaky power source blew out your AC adapters, and now that you have a good DC-in, all the adapters are non-functional so the computer just appears to be bad? An unlikely scenario, but you see what I mean....)
Thanks
Puan 2
Yorum Ekle
i have the same issue here, but my dc in is right at 24 v and dc out is 2v 5v and gnd x2 is that right for a normal working dc board?
Puan 0
Yorumlar:
Please start a new question so your question gets the attention it deserves. Thanks
tarafından
Yorum Ekle
Yanıtını ekle
toms sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,256
