won't boot from floppy, get error 41 when boot from HD
Here's a question for the "greybeards" out there:
I have a PowerBook 5300c, which when I attempt to boot it normally, gets an error 41 bomb when booted normally or with extensions off. I was running perfectly before I put it in storage a few months ago.
If I attempt to boot from a DiskTools2 floppy, it just spits the disk out and attempts to boot from the HD.
If I attempt to boot from a System 7.5.3 CD, using a SCSI external drive, I get a flashing ? icon, then it fails out to the internal HD.
The boot sequence appears to be correct; the bomb occurs right after the splash screen disappears, as the desktop is being drawn.
Thanks!
Bu iyi bir soru mu?
1 Yorum
I resolved the issue by formatting the internal hard drive and starting over. As an aside, this model will boot from a third-party external SCSI CD-ROM drive at ID 6. I'm currently about to replace the PRAM battery in this unit, documenting the process for some new guides.
David Iwanicki tarafından
