Ana içeriğe geç
Repair and disassembly information for Samsung's Galaxy A32 5G Android smartphone, released in February of 2021.
Can I replace the screen more easily if the frame is not broken?
I have an A32 5G with a broken screen that has come loose from the frame, but undamaged frame. The guide (https://www.ifixit.com/Guide/Samsung+Gal...) says that replacing just the screen is a different process, would it be a simpler one, or am I better off just removing the frame as well and replacing the whole assembly?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Darohan,
I personally find replacing just the screen is far simpler than replacing the screen and frame, although you do have to be more careful - especially with OLED displays.
On most android phones you just need to heat up the screen with a heat gun, hairdryer, heat plate or something similar to soften the adhesive until you can insert a pry tool under the display to remove it. However as in your case the display has already come detached, you can completely skip this step : )
From there, you can just apply new liquid adhesive such as E8000 to glue the new display in place.
Hope this helps, let me know if you have any further questions : )
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Darohan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 256
