Removing/Replacing LCD Screen safely
To prevent some of the issues others have had, can anyone answer the following questions?
First, if using a hair dryer, what setting should that be operated at? It would be much cooler than the heat gun, right?
Second, the iFixit basic set comes with a small, clear suction cup. Would that be sufficient for this project, or does it require the stronger pull of the heavy-duty cups?
Finally, must I reapply adhesive to the case when replacing the glass? Does the original remain tacky and re-bond on assembly? If I need to reapply adhesive, where would I get the right kind?
Thanks! :)
Bu iyi bir soru mu?
3 Yorum
Exactly what device are we talking about:-)?
oldturkey03 tarafından
ALWAYS replace the adhesive.
originalmachead tarafından
Macbook Pro 13" 2009
Regarding the Adhesive, what adhesive should I purchase, and from where. I cannot afford down time in the middle of the repair. The complete disassembly and reassembly should be completed in one session.
contact tarafından
