Ana içeriğe geç
Great vacuum and easy to repair.
Why won't my vacuum turn on?
Oreck won't turn on and handle power switch doesn't illuminate.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The electrical connector to the switch itself may be disconnected inside the handle.
  • After the obvious try a different outlet, verify the cord is plugged in both ends.
  • The connections to the illuminated switch in the handle are pressed on. After repeated dropping of the handle onto the floor, a switch connector may have fallen off the switch.
  • Unplug the unit and remove the screws holding the two sides of the handle together. Locate the loose wire and plug it back into the switch lug.
  • Loosely assemble the handle, plug in the vac and give it a try. If it turns on tighten the screws.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Randy Tolleson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 54
Her zaman: 1,053
