Ana içeriğe geç
On startup, folder with question mark and finder window appears.
when i switch on the computer i get the start up chimes and the grey screen with the apple logo, this switches off very quickly and comes back on with a small folder which has an alternating question mark and a picture of the finder logo.
I have already replaced the hard drive once with another one form the same model computer and it worked for a while (two weeks), but now it has exactly the same problem. i have also reinstalled the software with no luck.
the strange thing is that sometimes it does boot perfectly and sometimes this happens right after i have just had the problem with startup?
I have run out of ideas for what to do.
Bu iyi bir soru mu?
Puan 3
2 Yorum
how to install mac tiger 10.4 os
tarafından
Good day everyone!
I bought an ibookg4 here in the philippines and i have used it for like 3 months or more. But now, everytime i turn it on a folder, a finder and a question mark appears for like 1 minute and it shuts down suddenly. What should i do to fix this? Please help me.
I would greatly appreciate your response regarding this matter. Thank you and May God bless us all.
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
intermittent problems like this can drive you nuts. I have found that's it's usually RAM ESD (electro static discharge) problems. (Zapped RAM) Remove one of the RAM chips and see if the problem persists. Then do the other. One, if not both of the chips may be bad or one or the other other slots may be bad. This is not an easy fix and will require trial an d error to find. Persistence here will persevere.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
What rdk & I forgot to tell you is that the folder with the question mark means that the iBook can't find a system folder. This can be ram, failing hard drive, cables, corrupted system, loose connections, etc
tarafından
thanks mayer, i switched the RAM but that was only the removable one i can't find out how to switch the built in RAM, is that even possible without having to switch the whole logic board? thanks for your help.
tarafından
Yorum Ekle
Another possibility with this model is the fact that the hard drive cable wraps under the logic board and plugs in on the underside, and it's a small plug that does not stay seated well, and there's no surface around it which would allow for it to be taped down successfully, so it often has a tendency to come loose when the laptop is bumped, causing the frustration you describe. Sometimes if it's just loose you can clamp the laptop and apply pressure where the plug is, encouraging the contacts to connect without having to open it up.
I have a pile of 1.33GHZ versions of this model that I am reluctant to sell because they seem to always come back with this issue. If anyone has a solution to the cable coming loose, or if anyone has found a way of successfully securing the hard drive plug to the bottom of the machine, I'd be very interested to hear it. I'm tempted to try using a hot glue gun or something similar, since there's really no way to tape it down with any success.
Puan 3
2 Yorum:
I had a look inside another model that i have which is completely the same and the conneection is holding well, so i don't think its that but i will have a look. thanks for the tip.
tarafından
<<...If anyone has a solution to the cable coming loose, or if anyone has found a way of successfully securing the hard drive plug to the bottom of the machine, I'd be very interested to hear it...>>
The solution is to apply a constant pressure to the hard drive connector by putting a double side glued tape on the connector then make sure the lower metal shield will stick on it and installing a shim between the lower metal shield and the bottom case in the HD connector area. I would also tape the upper shield and the bottom shield together on the side and make sure all the metal shields and bottom case screws are well secured.
tarafından
Yorum Ekle
from thebosscigar@hotmail.com
Did you buy a MacBook between May 2006 and December 2007? If you did, keep on reading.
Apple has learned that a very small percentage of hard drives that were used in MacBook systems sold between during this period may fail under certain, unknown, conditions. The problem shows up as a flashing question mark on the screen.
Affected are the 13-inch black and white MacBook models with the following processor speeds and hard drive capacities:
  • Processor speed: 1.83GHz, 2GHz, or 2.16GHz
  • Hard drive capacity: 60GB, 80GB, 100GB, 120GB, or 160GB
If your MacBook falls into the age and spec range and starts displaying the flashing question mark on the screen then you need to take it to Apple or an Apple Authorized Service Provider where the system will examined to confirm if it is eligible for a free of charge replacement under this program.
This program covers affected MacBook models for 3 years from their original date of purchase or until August 15, 2010 whichever provides longer coverage. Apple will continue to evaluate the repair data and will provide further repair extensions if needed.
Kick off your day with ZDNet's daily e-mail newsletter. It's the freshest tech news and opinion, served hot. Get it.
Puan 0
1 Yorum:
Please give us a link to this so that others may be helped.
tarafından
Yorum Ekle
Here you go:
http://www.apple.com/support/macbook/hd/...
Puan 0
Yorum Ekle
i think it is really helpful for me thanks to the admin for this
<a href="http://www.dvtv.tv/">WATCH ONLINE TV CHANNELS</a>
Puan 0
Yorum Ekle
Please help my son, not knowing ordered an iBook g4 online. He's only 10 years old. He had a prepaid Visa card from Christmas. Again no hard drive?????
Puan 0
Yorum Ekle
Yanıtını ekle
thecross sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 21,240
