Ana içeriğe geç
Kasım 2016'da piyasaya sürülen, Nintendo Entertainment System'ın modern ve mini bir sürümü. Bazı pazarlarda Nintendo Classic Mini NES olarak da bilinir.
nes classic won't power on
i bought a faulty nes classic that i discovered won't power on. i checked for voltage with my multimeter and am getting 5 volts at the port and on every component i should be but still no power. what am i missing? it's a european model if that makes a difference
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
5v seems very low for a console
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
5 volts is all it needs since it's the mini and not the og nes
tarafından
@techlord yea just checked the power adapter specs, maybe a power button issue
tarafından
i checked the power button and reset button with my meter and they're functioning properly
tarafından
@techlord any bridging pins in the hdmi port ?
tarafından
hdmi port looks fine with no pins touching, micro usb port looks fine with no pins touching
tarafından
Yorum Ekle
External Power supply is 9VAC for 1.5A. After the diode rectifier bridge the supply goes to 13VDC.
3 tensions are used from this 13VDC power --> 9VDC, 12VDC and 5VDC this last one thru a LM805 egulator.
As a troubleshooting method you can connect a lab power supply tuned on 13VDC directly on the VIN leg of LM805 the regulator + GND, or on the big capacitor following the diode bridge.
If the console is still dead, the problem is elsewhere.
Puan 0
1 Yorum:
i don't have it anymore but it wasn't the og nes, it was mini. never figured out what the fault was. when i had it and checked for voltage i was getting 5 volts everywhere i should have but still no power and the switch was ruled out since it did work
tarafından
Yorum Ekle
Yanıtını ekle
Cheap gamer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 1,018
