Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
How do I fix or replace a broken ring/silent switch?
I dropped my 3G iPhone on the floor and now the ring/silent switch does not work. The volume is functioning fine and headphones work when in use. I can move the switch back and forth, however, the phone does not switch modes.
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
17 Cevap
Filtre ölçütü:
Seçilen Çözüm
There are a few questions on this, but I couldn't quickly find any, so I don't blame you for asking ;). iFixit though, has a guide for fixing this switch. The part you need to replace is the headphone jack assembly.
iPhone 3G/3GS Headphone Jack Assembly Görseli
Ürün
$14.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
I've just done the same thing with mine! (iPhone 3GS)
However, when I squeezed the front and back of the phone together (using thumb & forefinger) it gave it enough pressure to make the connection and the switch started to work again...and is still working!
I think the connection had just worked loose inside.
- It's a quick fix and worth a try!
Puan 3
2 Yorum:
I have an iPhone 6 and just tried this little trick. Fixed it instantly!! Thank you!!
tarafından
It worked perfectly thanks soooo much I was just about to take my daughters phone to the repair shop!! This helped a lot it’s back working perfectly
tarafından
Yorum Ekle
There is an app called GeneralInfo. It allows you to switch from ringer to silent without the switch. It only cost 99 cents and it works. My switch is still broken but now that I have the app it doesn't matter because I can change it on my phone.
Puan 2
2 Yorum:
Angel is a GENIUS! I downloaded the app for 0.99 cents and it works! Saved me $80 they wanted to charge to fix the switch
tarafından
You can do it for FREE with Assistive Touch that is in the General Settings of your phone. Check for instructions in the posts below. Jessica shows you how.
tarafından
Yorum Ekle
I don't think it's the switch. I had this happen to and I posted the questions here. When I took it apart, I found they the drop had caused a connector to pop loose. I think it was the one marked #5. It's a super tiny connector. I plugged it back in and everything worked. Might be worth looking at. The instructions are on here, just follow the instructions for taking it apart and look for the #5 connector to be loose.
Go to the "Repair" section of this site and find the repair for the mute switch and follow those to take it apart. Look for that small plug and make sure it's plugged in.
Puan 1
Yorum Ekle
Hello people gust had the same thing phone hit the floor and both volume and silent button didn't work and I tried squeezing the phone together by the buttons but only volume button worked as long as I kept squeezing it then I worked out if I lay the phone I'n my hand flat and slap the back and front of the phone at the same time as if I was clapping my hands together fairly hard for a few seconds firmly both buttons now work and all seems good but squeezing it together or any other thing I tried wouldnt make the mute button work but slapping it together hard has sorted them both so hope this helps as I read all your coments and used them to work it out so thanks to u all
Puan 1
2 Yorum:
Slapping my phone between my hands restored the audio ring tone; great tip; thank you!
tarafından
Clapping between my hands restored it thank you so much I'm so happy now
tarafından
Yorum Ekle
Hi All,
I had exactly the same problem, I cleaned it out with a pressure cleaner.
The solution to months of trying was..
ensure the botton on the side is switched unmute then..
go to settings > general > accessibility > assitive touch.
a little dot will appear on your screen > tap it > tap device > and tap unmute
it worked for me, and finally i can hear people ringing.. however i always have to turn the acessibility button on to change from silent to loud.
Puan 1
Yorum Ekle
You'll off course need a replacement, the part you need to replace is the headphone jack, it includes the ring/silent switch.
Ürün
$14.99
Puan 0
Yorum Ekle
I've actually had this problem before. I dropped my iPhone 3GS the first week I got it (actually it fell out of my jacket pocket). The switch felt a little sticky, but it still moved both ways. Of course I was mad I had already broken an important feature as the ringer volume doesn't go all the way down otherwise.
Oddly enough about 3 months later, I was showing someone that my silent feature was broken and to my surprise, it worked! I've always wondered what stopped it from working and eventually fixed itself. Judging by "forum"'s answer it sounds like my connector was loose, too. It must have been just loose enough to not work, but still be able to slide back into place eventually.
Puan 0
Yorum Ekle
The audio flex cable is probably still good. You need to disassemble the vibrate assembly to place the switch into the housing (it got knocked loose and is not aligned right). Alternatively, the switch sometimes becomes hyper-sensitive and vibrates too much. Just needs to be re-aligned (basically what happens when a new part is put in).
Puan 0
Yorum Ekle
I refurbish iphones on ebay and the headphone jack, well, sideswitch, is the most common thing to have issues. I'm forever replacing them, but these tricks are news to me! Might save me a bit.
Puan 0
Yorum Ekle
The general info app fixed mine - even re-enabled the switch if you can believe that.
And this is after I went to the apple store and they indicated I would need to replace the phone!!!
Dave
Puan 0
Yorum Ekle
the switch remains in the muted position all the time
Puan 0
Yorum Ekle
The GeneralInfo app was replaced by a new app named SilentAlert.
http://itunes.apple.com/us/app/silentale...
Puan 0
Yorum Ekle
Replacing the hardware would be great, but by God there's a lot of work to get to that device. I opted for the lazy way out and used software to work around it. Not a perfect solution, but it has been working for me:
http://bluescreensolutions.blogspot.com/...
Puan 0
Yorum Ekle
I have just wasted 2.99 on the silent alert app... It does not fix the problem. Yes I can change it not using the button but the switch still works and it still toggles from silent to loud every few seconds. Getting very annoying in my pocket!
Thanks.....
Puan 0
Yorum Ekle
The Silent alert app worked great for me!!! Now I can actually turn my phone to silent again! I was getting super frustrating having a phone that I could never make silent, particularly during meetings! The app is now $4.99 and well worth the $!!
Puan 0
Yorum Ekle
My silent switch was broken and SilentAlert helped me out. worth $4.99!!
Puan 0
Yorum Ekle
Yanıtını ekle
Javier Barrera sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 133,701
