Ana içeriğe geç
Samsung announced the Galaxy Flip 4 range at their "Unpacked" event on August 10, 2022. The new series of smartwatches Galaxy Watch 5 and Watch 5 Pro and the new series of Galay Buds 2 Pro were also announced.
Samsung Galaxy Z Fold 4 won't fully open
Recently, my Fold 4 stopped opening 100%. Now when using apps that require touch from the middle of the folded screen, it doesn't always register the touch. Is there any guides on how to fix this issue? I haven't even had this phone 2 years and it's a $2000 device. I've read a ton of complaints about this issue, but no real solutions to fix it other than take it to Samsung and have them repair, which they argue with some customers and won't repair it. Please help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had the exact same issue, my phone wouldn’t open fully. I disassembled it following some videos (there are plenty on YouTube). When I got to the hinge, I noticed not only a lot of dirt had built up, but also that the small brushes, which are supposed to clean the hinge, had come loose because the adhesive had weakened. This started clogging the hinge. There are videos where people open and close the phone in water or try to poke the brushes out with everyday objects, but I don’t recommend those methods.
I disassembled the phone and removed the brushes. If you’re careful, you can remove the display—it’s easy to lift and remove the adhesive underneath. It just takes time and patience. After that, it comes off nicely, but make sure to first remove the back cover and the external display because the inner display has ribbon cables on both sides.
Unfortunately, I rushed things a bit and tried to lift the display when the adhesive was already removed on one side but not completely on the other, which caused it to crack. However, it still worked fine afterward—just a small crack that’s visible under certain lighting conditions.
Once the inner display and the hinge are out, you can easily access the ribbon cables. It’s worth replacing them too, as they’re cheap and there are two of them in the device. These cables often break, causing display issues, Wi-Fi problems, touch issues, etc.
In the end, I had to buy a couple of ribbon cables and a new bezel because it’s tough to remove the old one without breaking it.
Good luck to anyone attempting this repair! While they say it’s unfixable, it’s not that complicated, you just need to be cautious.
Samsung Galaxy Z Fold 4 Fully Not Opening -- Hinge Repair -- QASWA TELECOM - YouTube
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Matt Pierce sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 30
Son 30 gün: 202
Her zaman: 771
