Ana içeriğe geç
The Chevrolet Silverado is a line of trucks under the Chevrolet brand and manufactured by General Motors. Mechanically, the GMC Sierra and Chevrolet Silverado are identical.
Changed rear master cylinder now even after bleeding I stillDon’t have
Replaced rear brake cylinder now even after bleeding I have no pressure 2010 Silverado rear wheel drive
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Found out that the new cylinder blew out Not understanding why this happened.
tarafından
If by new cylinder you mean a wheel cylinder inside the hub of a set of drum brakes then most likely you did not adjust the brakes properly after you repaired/replaced the wheel cylinder. The brake shows were allowed to spread far enough so as to let the new cylinder come apart.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Us it possible that you have either a ABS module that's gone bad or a master cylinder that is bypassing inside it's self in the first place?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
richard fritts sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 63
