Ana içeriğe geç
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
375 Soru Tümünü görüntüle
Nothing turns on, neither screen or leds
Like the title says, neither the screen or the leds turn on... The 3ds was in good condition, never gave problems. Ive seen online people say it might be the battery, but if it was the case, wouldnt it still turn on when connected with the charging cable?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I took my personal unit apart to make some pics to show you what may be your problem. Firstly no the 3ds will not boot if a battery is not present. The battery (even if dead) completes the circuit. If you plug it in without a battery a light will come on briefly, because it's checking itself. Once it discovers there's no battery the light will go off.
So here's the deal. This is fairly common in Nintendo handhelds. The contacts in the battery compartment are a little bit like springs. Over time, due to the constant pressure of the battery pressing up against them, they begin "sinking inwards". Eventually they "lose contact".
If this is what your problem is there are two "fixes". The easier one is to wedge some paper or something (thick enough but not too thick) into the crack on the top edge of the battery.
This will push the battery downwards more and possibly restore connection. How long it will last, no telling.
The longer term fix is to pull the contacts back out a little. Using a pick tool of some sort. I made my own out of a "safety pin", the end of which you can see in the pictures. Using the hook tool insert its end into the contact, they look like 6 contacts but it's really 3 pairs. Hook both in a pair. Like so.....
...and very gently tug directly away, arrow indicates direction. They are somewhat fragile. Don't pull too hard. You only need to bend them back out enough to make consistent long term contact with the battery. See how they line up almost perfectly with that horizontal trace? That is about as far out as they need to go.
Again be gentle, go slow, make small changes. Try to get them all as even with each other as possible, however "perfect" isn't required. Test, if all is well great, if not tug them a pinch further, test again. Eventually you'll get the sweet spot. Good luck.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thank you, but the problem was that i was pressing the START button instead of the POWER one. I simply forgot how to turn it on.
tarafından
@sim333 :) Well at least it was something simple. Happy gaming.
tarafından
Yorum Ekle
Yanıtını ekle
ꜱɪᴍ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 39
