Ana içeriğe geç
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Soru Tümünü görüntüle
Can't see the device after replacing disk
My ipod video stopped working. It would either say the battery was low or it would just display the support web address. I decided to replace the disk and since I was replacing it I upgraded from 30gb to 60gb. I purchased a new battery, headphone/hold switch, front, back and disk. Now it just clicks. I can't see it in iTunes or windows "My Computer". Nothing shows up on the display. Any ideas?
Thanks.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
gocleveland, check your HDD cable. I have had plenty of 5th gen iPod that had a broken cable. Make sure that you check the way it is inserted. It is possible that it is broken as well. Anytime I now change a HDD I also replace the cable. Also make sure that you replace the HDD with the same brand. I do know that the Toshiba and Hitachi drive require a separate HDD cable. If you can, get a USB-to-ZIF adapter and check your HDD separate from your iPod. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
gocleveland sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 515
