Ana içeriğe geç
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Soru Tümünü görüntüle
My laptop won't completely boot up.
I hit the power button and hard restarted my computer due to Safari freezing. The machine restarted, the apple came up in the white screen then goes to blue screen instead of Leopard background. Now all I can do is hit hard restart and it will do the same thing. Apple/white screen then to blue.
It will restart in safe mode but it won't do anything. Any thoughts other than logic board?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can first try starting in Safe Mode by holding down the Shift key. Next try booting from your installation disk by holding the "Option" key down. This will load the bootloader, where can choose the OSX installation disk to boot from. On about the second page you will see the drop down menu at the top of the screen. Go to Utilities - Disk utility and run the verify. If needed run the repair. Then try booting from the hard drive. If this fails reinstall the system.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hmm, it could be that some kernel is corrupted. Have you tried booting from the Leopard install disc?
Puan 0
Yorum Ekle
Probably need to reset the PRAM.
Puan 0
Yorum Ekle
Change hard drive on a aluminum 12" Powerbook G4 after replacing hard drive I tried installing 10.5 it asked for base system, put in 10.4 it asked for 10.3. put in a copy of 10.3 and nothing, it just flashes the question mark, file and the two faces what can I do.
Puan 0
Yorum Ekle
Yanıtını ekle
Chuck sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,680
