Ana içeriğe geç
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
546 Soru Tümünü görüntüle
Will not start, good spark
Cleaned carb, replaced gas, good spark, will only run for a second if I pour gas into carb.......wife claims it back fired when she was starting it for first time this year......model 917273812 craftsman....any suggestions??/
Bu iyi bir soru mu?
Puan -1
1 Yorum
What engine size and model is your mower?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
walter, check the needle valve and float in your carb fuel bowl, make sure that it is not stuck and clean. Check the jets and passageways for any debris. Also check for the gas tank lid, make sure it is vented. Check your fuel lines and fuel filter and make sure they are not pinched/cracked or dirty. Finally check to make sure your timing is right. Just because you have a spark does not mean that it is at the right time. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
walter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 727
