My laptop won't turn on
When I press the power button the keyboard lights up in a split second then turn off again, I already done troubleshooting like draining the power(removing RTC battery, Main battery) and holding power button in 10 minutes. I already have switch the RAM locations. Please help me 🥲
See the video below:
Bu iyi bir soru mu?
Puan
0
Hi @eugeneeridao
Does the laptop indicate that the battery is charging when you just connect the charger to the laptop and don't try to turn on the laptop?
jayeff tarafından
Yes, the charging indicator lights up, but when I pressed the power button it turned off then the same thing happens again.
eugene eridao tarafından
@eugeneeridao
What colour is the charge light and if it is amber is it steady or blinking?
jayeff tarafından
It's a steady red. I had an update; it miraculously booted, but I did something. I tried to heat it up using a hair dryer, then it booted. After that, I shut it down, and the problem came back again.
@eugeneeridao
Try leaving it on charge until it indicates that it is fully charged i.e. charge light = white, before trying to turn it on.
If it never turns to white I think that there's a problem either with the battery or the power supply circuit on the motherboard
jayeff tarafından
5 tane daha yorum göster
