control lock is dipayed
The washer is stuck on "control lock"
Bu iyi bir soru mu?
Adin, here is my answer from a similar question "the normal procedure is to hold down the "end of cycle signal" (drain/spin)button for 3 to 5 seconds. The only other thing I could see is that the control interface has failed and has a stuck or shortened keypad. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min. There is also the possibility that the interface ribbon cable became dislodged. Let us know what, if anything, work. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 511
