Ana içeriğe geç
32 veya 128 GB depolama alanı seçenekleriyle sunulan 8. nesil Apple iPad Wi-Fi için onarım rehberleri, söküm bilgileri ve sorun giderme bilgileri. Eylül 2020'de piyasaya sürülmüştür. A2270 model numarasıyla tanımlanır.
Can't Set Up Touch ID After Screen Replacement
I replaced a shattered screen for a coworker's iPad 8. I pulled the old home button and reinstalled it on the new screen. It functionally works, but I got an error message that Touch ID can't be set up. When I go to add a fingerprint, screen shows "FAILED Unable to compete Touch ID setup. Please go back and try again." Is this simply an Apple ID issue, or do you think the home button was damaged? Any thoughts would be appreciated!
Bu iyi bir soru mu?
Puan 0
5 Yorum
@czjohn i understand. I just niticed you LITTERALLY JUST COMMENTED.
tarafından
@czjohn i can answer this one for you!
tarafından
Not entirely sure if this thread was hijacked or not, but @dadibrokeit, if you have some advice, I'd love hear from you. I did a search and saw a couple of posts concerning iPhone 6 Touch IDs, but nothing that really speaks to my issue. Thanks for your advice in advance!
tarafından
What if the cable is fine but the slot it plugs into what if that has missing connectors on it how do you replace that on the mother board
tarafından
@stevenstandley That replacement is indeed possible, but requires rather advanced microsoldering skills and equipment. I'm pretty technologically advanced, but that's one I'd leave to the professionals. A reputable repair shop that can handle board level repairs should be able to handle that repair easily.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi John,
Unfortunately, it's all too easy to damage those delicate flex cables an the connections to the chips mounted on them, especially with the amount of glue and length of cable used on this iPad.
At this point, realistically all you can do is to recheck the connector where the home button plugs into the motherboard. Unplug it and clean the flex cable with some 90% or higher isopropyl (rubbing) alcohol then resecure it and retest.
Resim
If that doesn't do the job, the next step is to carefully examine the home button's flex cable for any kind of tears, scratches or damage. With some fair-to-middling solder skills it's possible to replace the length of flex cable most likely to get damaged as shown in this video.
Apple iPad home button torn Flex / cable repair - YouTube
This is showing the procedure on an iPad 7, but as nearly as I can tell the iPad 8 uses a very similar flex cable so the same operation should work on it as well. Outside of that, the only other possibility would be to locate the diode mode readings for the home button connector and test them, but unfortunately I don't know if they even exist. I did find some for an iPhone 7 home button I was trying to repair, so it's not impossible, but I don't know where you might find them. Here's some connector information for the motherboard I ran across.
J3800.rar - Google Drive
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
I was worried about that. The screen wasn't just cracked, it was shattered and the edge wasn't intact in places. Consequently, removing the home button wasn't as straightforward as it would normally be.
However, do you think the button would still function if the cable was damaged? As far as I can tell, the button functions fine; its just that I get an error message that "Touch ID can't be set up", which makes me think it could possibly be an Apple ID issue.
I'll meet the client on Saturday and have her log in to her Apple ID. If that proves to be the issue, I'll reply and let you know!
tarafından
@czjohn On the iPhone 7 where I had a damaged button, that was exactly the situation; the home button function worked fine but the Touch ID wasn't available, so yeah, it can definitely happen that way. I don't think you're going to get anywhere with the Apple ID approach, but it certainly can't hurt to check it out before you have to open the %#*@ thing up again.
tarafından
@dadibrokeit You're amazing. Thanks for the help!
tarafından
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 51
Her zaman: 1,173
