Ana içeriğe geç
My disc tray button keeps beeping, but the disc tray doesn't open
Even if i try and open the disc tray it doesn't open, i thought the ribbon cable is damaged but the power button is fine, so it's not that, can anyone help? I dont want a digital only Xbox 360.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Is there currently a disc in the xbox 360?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Filip!
In my experience it still could be the power switch board cable... But it's also possible that your drive is dying.
What do you hear when you try to open the disc tray?
If you don't hear any sounds > power switch board ribbon cable could be faulty.
If you hear the drive trying to open, but it stays shut > faulty drive/rubber belt
Guide for the ribbon cable > Xbox 360 S Ön Panel Değişimi
Guide for the drive: Xbox 360 S Optik Sürücü Değişimi
If it's possible to create a video for this and share it with us, that would be great!
Xbox 360 S Optik Sürücü Görseli
Kılavuz
Zorluk:
Zor
40 minutes - 1 hour
Xbox 360 S Ön panel Görseli
Kılavuz
Zorluk:
Zor
30 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
The disctray button sounds like it presses itself, constantly. Its an annoying sound so i might just unplug the ribbon cable and use turn it on using the controller, digital xbox 360.
tarafından
Hi! In my experience (repaired a lot of them) this is caused by the ribbon cable… it’s damaged OR not fully in… best thing to do is to check if it’s probably seated, if this is the case, then replace it for a new one. Good luck!
tarafından
Yorum Ekle
Thanks for the help everyone, but the xbox now has the RedDotOfDeath by accidentally damaging the logic board during an attempt to RGH3 it. Thank you.
Puan 0
1 Yorum:
Hi Filip! Ah, this is hard to fix... Probably for the best to replace the motherboard...
tarafından
Yorum Ekle
Yanıtını ekle
Filip Reszka sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 320
