Ana içeriğe geç
KitchenAid KTT340OB0, Bagel (simit) ve Isıtma işlevlerine sahip iki dilimlik bir ekmek kızartma makinesidir. Bu ekmek kızartma makinesi ilk olarak 2002 yılında satışa sunulmuştur.
Why won't the lever lock?
the lever doesn't lock down on Kitchen Aid RMKTT200 toaster
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
  • There may be a mechanical failure or just an obstruction at the latch that holds the leaver down.
  • Sometimes the toaster has safety features in-place that test there is live mains voltage before it will latch the lever
    • Try replacing the fuse
A rough idea of how this is ment to work;
  1. push leaver down
  2. latch grabs it and holds it down, connecting the heating wire mesh to live voltage
  3. a bimetallic strip will slowly deform as it heats up
  4. once fully heated it will be deformed enough to let the latch slip and release the leaver, popping back up and disconnecting the heating element
If you are not comfortable working with live mains voltage, (and only qualified electricians should be) I would not recommend taking your toaster apart or modifying it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
john c. davis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 464
