Ana içeriğe geç
Model A1225 / 2007 Ortası ve 2008 Başı / 2.4, 2.8 veya 3.06 GHz Core 2 Duo işlemci
Won't power on GPU fault?
I recently began fixing an iMac a1255 the first 2 diagnostic LEDs turn on but unfortunately the other 2 fail I presume it would be a GPU fault but was wondering if there were other troubleshooting steps to take
Update (05/09/24)
Update iMac was left sitting around till I sourced a CPU to try came to install first I tried powering it up before replacing but now only got diagnostic lights was working yesterday and nothing was done
Update (05/15/24)
Update got new ram and received error lights again but nothing else swapped CPU but no change till the morning when it booted up a few times but then it got stuck at a white screen and then multi coloured lines as well GPU ? Thanks in advance
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Sadly LED3 is active when the CPU & GPU are communicating to each other within the logic board and LED4 is when the logic board and the display are communicating to each other.
What is the back story here? Did you try swapping the CPU?
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Ah I thought that it was only GPU and the screen wasn't working due to the GPU fault.
I picked the iMac for free for parts seemed to be opened before began troubleshooting as no sign of life used different cable and then LEDs 1and2 began working as wells as the chime but nothing on screen tried reseating the GPU to no avail
I will see if I can find a cheap CPU to check it with
tarafından
@donaghmurphy - Sadly it does sound like the GPU chip has failed.
tarafından
Replaced the GPU and it's working perfectly
tarafından
Yorum Ekle
Yanıtını ekle
Donagh Murphy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 265
