Ana içeriğe geç
The Acer Aspire 5 A515-43 is a slim and silver Acer laptop with a 15.6 inch Full HD display, Ryzen 5 3500U processor, 8 GB DDR4 SDRAM, 128GB SSD and Backlit Keyboard. In this page you’ll find repair and service information related to the Acer Aspire 5 A515-43. Models of this laptop include: R057, R19L, R1JA, R2MQ, R33M, R3GE, R4Q7, R4YY, R4Z2, R5HG, R5QW, R7B8, R7MS, R9B1
5 Soru Tümünü görüntüle
Something happened and your pin isn't available (Windows 11)
It say's something happened and your pin isn't available its been 3 weeks and I still cant find any video to fix it the pressing shift thing troubleshoot and command prompt and regedit none of that works please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @ibrahimb
Here's how to get into the Windows Recovery Environment menu. Hopefully from there you may be able to fix it.
Start the laptop and when it boots into Windows, press and hold the Power button for >4 seconds to force stop it.
Do this 3 times in a row i.e. Start → boot → force stop → Start → boot → force stop → start etc.
On the 3rd attempt it should boot into the WRE menus.
If it does, select Troubleshooting → Advanced → Start up repair and follow the prompts.
Do not select Reset this PC because if you select the wrong option after this you may erase all your data as Windows will be reinstalled.
If you can't get into the WRE menus this way perhaps the recovery partition has become corrupted.
You can create a USB recovery drive from any known working Win10/11 PC. All you need is an 8GB USB flashdrive and 40-60 minutes of time. In the host PC go to Control panel → Recovery → Create a recovery disc and follow the prompts.
When you have the recovery drive, turn on your laptop and get into BIOS (press F2) and change the boot order to USB 1st boot option. Save the changes, insert the USB drive into the laptop and then restart the laptop and it should boot from the USB drive into the WRE menus.
If it does follow the directions above regarding Startup repair.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
can u send a video or no
tarafından
@ibrahimb
Sorry no.
tarafından
ok I understand
tarafından
Yorum Ekle
Yanıtını ekle
Ibrahim B sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 42
