Is it possible to access the SRAM directly to recover data?
Is it possible to recover data from an iPhone that's damaged beyond financially viable repair by accessing the SRAM directly with an SRAM reader.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
antony, in order to get anything out of the NAND memory, you will require to either purchase a NAND reader $$$ or build your own. for that you will require the data sheet etc. Here is the link for a site where you can get an idea how to build it, here is more of a background information about it, and some more good information on here. There is a good reason why companies charge extensivle yfor data recovery :-) Hope this helps to get you in the right direction. Good Luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,056
2 Yorum
Thank you oldturkey03 - the links you provided are very interesting.
The spec. sheets for the NAND chips are easy to find. I also found one interesting website that sells readers http://flash-extractor.com, but was unable to find specific instructions on how to build a reader or any iPhone data recovery services that read data directly from the NAND.
Antony tarafından
Antony, that is where link number 1 in my answer comes in handy. There are some commercially available, those are the ones that are for law enforcement, data recovery specialists etc. Very $$$$
oldturkey03 tarafından
