Ana içeriğe geç
Model A1001 veya A1025 / 667, 800, 867 MHz veya 1,0 GHz G4 işlemci
Won't boot passed blue screen?
Can only get in single user mode.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try booting in Safe Mode by holding down the Shift key. What system are you running. Start up from the installation disk by putting the disk in the CD drive and holding down the "C" key while hitting the start button the run Disk Utilities and see if you can repair the system.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Too fast for me--like the idea of booting into the safe mode. Ralph
tarafından
Yorum Ekle
En Yararlı Yanıt
If possible boot with your OS disk and run disk repair until it finds no problems. With luck that will clear the problem. You should do a backup of your data first because you may end up needing to format and reinstall. Backup first and then repair. Good luck. Ralph
Puan 2
1 Yorum:
Good idea ;-) +
tarafından
Yorum Ekle
Yanıtını ekle
Ron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 1,459
