Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
How to fix iPhone screen if it looks like a negative print?
My iPhone fell from my hands. When I picked it up, the screen lost the real colors. It looks like a negative print photo!
What can I do to fix my iPhone?
Bu iyi bir soru mu?
Puan 98
38 Yorum
I have this problem on a 3g iphone, so its nothing to do with the accessibility function found only on 3gs.
If I press top right corner of display image flips upside down.
I don't believe water damage is the culprit, any other ideas?
tarafından
Hi my iPhone 5s is having the same negative problem. I have tried all the fixes suggested here but nothing is working. It wasn't dropped. I did up grade to Yosemite earlier today though on my laptop. Could this be the reason?
Please help
tarafından
I just downloaded Yosemite but clicking the home button 3 times doesnt work any other suggestion
When i turn it off in accessibility it will ask me Are you sure you want to disable inverted colors. then when I say ok it stays the same Not sure what to do.
tarafından
I have the iphone 5s. It had the same negative problem. I have tried the home button 3 times, as well as the Settings-General-Accessibility-INvert Colors. When I turn the invert colors it just makes the screens black and white, but no color. Grrr.
I don't have any white on black option, either. Just an invert colors and grayscale. The grayscale doesn't seem to do anything.
Can anyone help?
tarafından
Erica I had exactly the same problem.My screen turned negative in my pocket. After reading all the Q&A online on how to fix it everybody was talking about how to go to Accessibility and turn "invert colour" botton on or off. I did the following : General/Accesibility/Interaction/Accesibility Shortcut and tick Grayscale and Invert colours. By doing this you will make sure that you will be able to access those two functions with your home button when you press it 3times. So what I did, I changed my screen from negative to black and white by turning "Invert colour" button on only and then from the locked screen I triple clicked the home button and ticked Grayscale. My phone had the colours restored. Thank god. Hope this helps :)
tarafından
33 tane daha yorum göster
Yorum Ekle
26 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try clicking the Home button 3 times (really fast). If that doesn't fix it, go to Settings/General/Accessibility/Triple-click Home, and select the "White on Black" option. Then, triple-click the Home button.
Bu yanıt yardımcı oldu mu?
Puan 81
76 Yorum:
Wow! I just tried clicking the home button three times like you said and instantly my negative images turned positive! Thank u thank u thank u for your awesome help! I wonder if it might work for my checking account!? :)
tarafından
Thanks for the tip. Even my I phone fell down twice and after I triple clicked and chose the black and white option.. to my surprise, within a second, my phone turned normal. Great..
tarafından
thank you!!! It worked!!
tarafından
wow u da best!!!
tarafından
Wow! How awesome! So quick and easy! THANK YOU!!!!!!!!
tarafından
71 tane daha yorum göster
Yorum Ekle
I had same problem with my 5s, turned blk and wht, tap screen 3 times with 3 fingers, go into choose filter then tick none, job done!
Puan 22
10 Yorum:
At last I got the answer.. thank you very much
tarafından
Brilliant - got the job done! Thanks
tarafından
Yay! This worked. Thank you!
tarafından
Thank you, Paul! How on Earth was the average shmo like me supposed to know that??? :D
tarafından
thank you , i had a headache ,
tarafından
5 tane daha yorum göster
Yorum Ekle
Don't bang on anything. Go to setting on main screen. Click on General, scroll down to Accessibility, click. On the next screen make sure invert colors is turned (OFF) This is for the Apple 4S Iphone
Puan 15
5 Yorum:
Wow this worked! Thanks!
Now what caused the screen to turn negative. I did not drop it or anything. I had it in my pocket and when I pulled it out, it had the negative screen.
tarafından
Mine was in my back pocket also so all I can figure is that since pressing the home button 3 times makes it go negative also it must have happened while it was in my pocket. Thanks for the help.
tarafından
OK. I was stumped. I found this page. The triple click on the home button did nothing for my 5S. But the Settings/General/accesibility/INVERT COLORS-ON worked immediately. THANKS
tarafından
by brian thanks i've been trying all night to find a way to fix this problem on my iphone 4 settings/general/accesibility/ and most important [ =====INVERT COLOR ====] worked rite away thank-you . PS i thought the camera was shot for good
tarafından
I did it it dosent work
tarafından
Yorum Ekle
Experienced same problem on iPhone 3 GS with iOS5 just installed. Triple clicking home button dod not work. Solved problem settings/general/accessibility/ turn off 'white on black' (no idea how it self selected).
IOS 5 working fine, no problem downloading (8 min via my Macbook)) now launch day bottleneck over.
Puan 4
11 Yorum:
Thank you for the help, i am computer illiterate and i found this to be a fix i even understood. gen/settings/access/ turn off Black/White. i aslo do not know how it selected this mode originally.
tarafından
Thank you. Went back to the settings, as suggested. I guess I must have accidentally pressed a certain sequence and let the negative image loose! Merci from Montreal.
tarafından
thank you so much, my mum would've killed me if i didn't fix it, cause it was hers not mine!
thank you!
tarafından
Thank you
Worked easily !
tarafından
Great: also on a 4G three times home made it all positive again. I wasted more than an hour trying to find a menu option to do the same, I google 10 seconds and have solved the problem!
tarafından
6 tane daha yorum göster
Yorum Ekle
I have press 3 time of home button but it I have press 3 time of home button but it doesn't work on the other hand my iPhone 3G ios 4.2.1 has no accessibility option so how can I fix it please tell me
Puan 3
1 Yorum:
Iphone5c cant get black and white off after all that. Turned off bold setting it said it was going to restart.omg now its really screwed up. Extreem big letters. Shut off again same
tarafından
Yorum Ekle
I did the settings/general/assessability/invert colors trick on my 4. Thanks for the info.
Puan 2
5 Yorum:
I have the same thing but on a iPhone 5c
tarafından
Happened to my iphone 5c also. I had to turn off gray scale and invert colors. That worked.
tarafından
thanks. Ali got it...
tarafından
I have a lg phone
tarafından
How do i fix my lg from looking like an exray
tarafından
Yorum Ekle
Apple I-phone 5 S
I just down loaded the newest version of I-OS7. Phone screen went to inverted colors or looked like it was a negative. The first fix of tapping the Home screen three times did not work. I then went to 'Settings', then 'General', then 'Accessibility'. Once there there is a heading labeled vision. Look in that column for the Invert colors button. Its probably turned on. Tap it to turn it back to normal.
Puan 2
2 Yorum:
Oj how can we just reset the phone?
tarafından
Thank you so much
tarafından
Yorum Ekle
My iphone 5 turned black and white. Went in to settings -accessibility- vision and undid the invert colours. So now it is even more black, like a neg.
Have read all your answers, but nothing works. When you say home button, do you mean the main button down on front? Thats where I click 3 times right? So have accessed _accessibility-from there to. Still doesnt work....So in anyway, also did restart it of course.
Update
so I had to reset it. so now I have colours!!!
Puan 2
2 Yorum:
I have a 5c , tried everything suggested - read the above post and RESET . I have color now . Easy and less time wasting option ..thank you.
tarafından
Ty im a phone moron n i tried all night, ty for yer time
tarafından
Yorum Ekle
I panicked to my iPhone 4s went black and white tapped 3 times back on oh what a relief
Thanks heaps and heaps.
Puan 1
Yorum Ekle
ipad pressed button 3 times now perfect
Puan 1
Yorum Ekle
Yeah this helped a great deal Patricia
Puan 1
Yorum Ekle
I think that i leaned back and so was my iphone 4s behind me. Now the colors on my screen are completely messed up. I dont know what to do. I tried to call my friend. It worked. Then i tried to text my friend. It worked. Then i tried to turn it off and on. IT DID NOT WORKED!
Puan 1
Yorum Ekle
I have an IPhone 4 and unfortunately nothing is working for me either
Puan 1
Yorum Ekle
Go to Settings, General, Accessibility, Turn ZOOM OFF.
Puan 1
Yorum Ekle
I'm having the same issues right now with my iphone 4. I have done all of the above solutions but it's not working. I have tried the invert, the triple home button and also the turn off zoom. Soft reset is also not working. Please help. Is there any way I can fix it without having to buy a replacement screen?
Puan 1
Yorum Ekle
I can't see anything on my screen but it responds to my touch. I didn't drop it or anything but it just turned into lines. Please help meeeeee
Puan 1
2 Yorum:
i have the same problem please help!!!!!!!
tarafından
my screen is white and cant even see rest of it
tarafından
Yorum Ekle
Hello , I have an IPhone 6s and had a problem where the screen looked as if it had an orange filter on it. If anyone has this issue Settings>Display and Brightness>Night Shift>Then switch color temp to the lowest setting! Hope this helps!
Puan 1
Yorum Ekle
Thank you for your help
Puan 0
Yorum Ekle
Hit the center button for apple ipad 3 times or center button it will change the mode from color mode to ex ray mode
Puan 0
1 Yorum:
Holy cow! Worked for my iPod! Triple click woowho.
tarafından
Yorum Ekle
My Iphone 4 screen randomly flickers at the bottom and then the colours go all weird but EVERYONE is putting the same answer
...Triple click home or go to accessibility and make sure inverted colours is not selected, I have done this a good amount of times now to realise this is not what is wrong, so I am asking please if there anyone out there who has gone through what I am going through or has any idea what is wrong..Please help me.
Puan 0
1 Yorum:
Mine is an Ipod touch 4 and I have the same problem I think. It looks like a photo negative, but parts cannot be seen to read. I also tried the fix mentioned here without success. I was told to replace the digitizer. I have not done so yet, but would accept a confirmation on this.
tarafından
Yorum Ekle
Hello i hope that someone can help me ... Recently I have bought an iPhone 4s but after a while I had that problem that the screen looked like invert colours was on but only if i viewed it from a angle or on dark images/videos. Is there a way to fix it without having to buy a new screen ?
Puan 0
Yorum Ekle
None of the above written aswers are working on my Iphone 4s. What can I do?
Puan 0
1 Yorum:
Go to General in Settings, Accessibility, Turn ZOOM OFF.
tarafından
Yorum Ekle
i took my iphone 4 apart and put a different screen on it but it didnt work so i put my old one back on it and it now has all neon colors and has black ink spots and i dont know why
Puan 0
Yorum Ekle
So I have iPhone 5c and I had same negitive issue after playing in settings for a while and I went to Settings/General/Accessibility and then turned OFF Gray Scale and that worked for me. :) Ughhhh!! That took forever though!! Not fun at all!! Ughhh!! So glad that's over and so happy to finallyyyy have some color up in here again!!! Just sayin!!
Puan 0
Yorum Ekle
Same prob with 5c and did all the above in various sequences and finally got color back but don't know exactly how I did it....But thanks to all for the help.
Puan 0
1 Yorum:
I already tried all of the suggestions, but nothing happen to my iphone7, somebody could help?
tarafından
Yorum Ekle
I have the same problem with everything looking like a negative, but I have the iPhone 11 Pro Max?
Puan 0
Yorum Ekle
Yanıtını ekle
massiel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 69
Her zaman: 614,303
