The iMac is Apple's line of all-in-one desktop computers.
6564 Soru Tümünü görüntüle
Can I install a 2.5'' Seagate HHD in iMac?
My iMac's (Early 2008) Harddrive seems to be failing.
I would like to upgrade to a Seagate 2.5'' Hybrid Drive, the Momentus XT.
How can I upgrade my iMac to that Hybrid drive?
Thanks
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Drive replacement like this is doable but you need a 2.5 to 3.5" drive adapter. The drive will not fit in this computer as-is. You will need this adapter to install the hard drive. I have also supplied the guide below.
If you really want to use Seagate here's the drive you want. As this is a 2015 revision, count on this drive being discontinued. I'm simply including the link as a reference.
iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
Okay, now for the revised answer from a new era.
No, don't use Seagate. At this point in time, their drives are absolute junk and simply do not last. I also tried a SSHD before and I'm not impressed. The only thing Seagate is good for is target practice these days.
What I would do is get a WD Black drive and a optical drive caddy for the SSD.
You will need one of these to replace the DVD drive and then you can install an SSD into this and load the OS here. Get a Samsung 850 Pro SSD.
Without specifics on this, I can only guess what computer you own. As such I am not linking guides. You need to find them.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
miguel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 2,389
