Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1504 Soru Tümünü görüntüle
Won't turn on unless charged but says 100% battery
I dropped my Iphone in the toilet a few days ago. Clean toilet and it was only in the water for two seconds before I got it out, dried it with a towel and submerged it in uncooked rice. I didn't know it had to be off while in rice, so maybe the water got to it before the rice could help. but after a night I took it out and it seemed dry(er) at least. Plugged it into the charger and it worked in the morning, for a few hours before it suddenly went black. Went home, put it back in rice, thinking there still might be water. Gradually, the phone seemed to get more and more ruined. Gave it to a friend to take apart and blowdry. He didn't take everything out, just merely opened the phone and dried it in intervals for an hour or so. He returned it but all it would do would flicker on and off ONLY when plugged into a wall charger. Day 5, I'm trying to turn it on but it won't. Only when I plug it in. Ridiculously enough, once plugged, it says there is 100% battery.
But once I pull out the charger, it will immediately die. Is it a battery issue despite the fact that it seems to be able to charge? Or is this the end? Please please help me. I've only had this phone a few months (but it's jailbroken/I use t-Mobile)
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Karen Pham, first thing I would suggest is that you follow this guide to clean your iPhone. If you do not clean it now, you will have a much harder time later when your board has corroded ;-). After you followed that guide to clean replace the battery. iDevice batteries do not like water and I am certain that is the problem with your phone. It will worsen if you do not get rid of the water damage. Rice is a nice first aid, but not a fix. Re-evaluate after you do those aforementioned steps and see what damaged , if any, you have. You'll find the guides to work on your phone right here. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Karen Pham sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 7
Her zaman: 2,767
