Ana içeriğe geç
Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
Can you identify which camera part replacement I need?
Hi,
I unfortunately smashed the back of my Iphone 12 and now the metal ring around the camera and the lens (I think these are the parts) have fallen off. Is someone able to clarify which specific parts I need to replace and possibly provide a url for purchasing them?
The reason they fell out is because the smashed back has caused a bit of glass to fall out - do you think gluing the new parts in place will work or I will need to replace the whole back, as the glass will realistically continue to deteriorate?
Any help will be hugely appreciated! Thanks,
Gabriel
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi,
I have now received the lenses and bezels and because they are normally welded to the frame, I am going to have to try and glue the new ones back on - unsure how well this will work, but want to try. Unfortunately, I can't find any direction on the lens/bezels online. Which lens is for wide angle (this needs replacing) - the thinner of the two? And would I need to glue the lens on first and then the bezel (the metal ring) on afterwards? Sorry, if I have butchered some of the terminology there!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think you need:
Note that the lens and bezels are welded to the frame and that the back glass is pretty hard to repair on these devices. Here's a community-contributed guide that gives you a sense of the process: iPhone 12 Back Glass Replacement
Replace a broken or scratched rear panel with this new blank aftermarket rear panel. Görseli
Ürün
iPhone 12 Aftermarket Blank Rear Glass Panel
$24.99
Replace scratched external lens covers and metal bezel rings for the rear-facing camera of your iPhone 12. Görseli
Ürün
iPhone 12 Rear Camera Lenses and Bezels
$8.99
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hi,
Thanks a lot for your help! Yes I suspected replacing the back was difficult - I'll see if I can find a makeshift solution for the time being (likely involving tape and glue haha) and will see how it deteriorates.
Thank you.
Gabriel
tarafından
Hi,
tarafından
Yorum Ekle
Yanıtını ekle
Gabriel Osborn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 114
