Test water feed solenoid/ solenoids.
1 On rear of unit, check water feed by cracking the compression fitting and make sure water is getting to fridge through ice maker line. Bring a towel.
2 if water is at solenoid, have someone attempting to dispense water. If nothing, unplug solenoid valve and test for power with meter. Should test 120 volt ac when called upon for water is dispensing If no water out when plugged in, valve is bad. Replace. Very common failure part. 2-3 screws, 2 fittings, one wire plus or two wire depending on make model.
3 if no power to valve when requesting water dispense, things get tricky. Make model/control board, door closed signal etc.
4 do a hard reset, unplug and wait 5 minutes before plugging back in.
Make and model really helps in the forums.
Optional, Insist domestic partner caused failure, but in reality, pure coincidence.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
