Ana içeriğe geç
Apple 20 inç Intel iMac cihazlar için onarım rehberleri ve destek.
Won't boot up
Circle with line through it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Well that’s not a good sign, but a repairable one! Either the OS is missing or damaged on the drive or the drive its self is damaged and will need to be replaced.
As Apple produced a very versions of this model you’ll need to figure out which is yours 20” iMac listing
As an example review this guide on how to gain access to the drive iMac Intel 20" EMC 2105 ve 2118 Sabit Disk Değişimi it will give you the general idea what’s needed. Be careful as this series uses an older version of SATA interface so you will need a drive which supports the older version SATA II (3.0 Gbps) if the drives spec sheet doesn’t list this you’ll need to find another drive.
Now the tricky part! Hopefully you still have the CD’s/DVD’s that came with the system as you’ll need the OS installer disk to re-install the OS and depending on what your system is your options maybe limited as to the highest version you can run on your system.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Irene Villanueva sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 142
