Ana içeriğe geç
Model A1213 / 8, 16, or 32 GB capacity
216 Soru Tümünü görüntüle
Soru Kapandı
Why does my iPod not turn on
The problem is that my aunt gift me an iPod touch 1g in September 2011 When I'm gonna connect the iPod touch to configurate it do not do nothing I mean it don't turn on don't do anything Please help me
Bu iyi bir soru mu?
Puan 0
3 Yorum
Joe Rivera, have you tried to connect it to a wall charger? Did anything happen to the iPod? Has it been connected before? Have you done any work on it, does it have any water damage?
tarafından
oldturkey03 I have connected it to the wall for first time and it doesn't do anything The only thing it does is when I connect it to the wall charger it says connect to iTunes but when I disconnect the charger it turn off, And when I want to restore the iPod from iTunes it says error 1604 I try everything
tarafından
If it comes on with a wall charger but it turns off when you connect it to your computer, let it charge longer. If that still will not keep the iPod on, replace the battery. For the 1604 error, check on here http://forums.techarena.in/tips-tweaks/1...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Right now I would start off with trying to charge a battery with a wall charger, not' your USB port. It is possible that the iPod is totally discharged. If it does not charge, check the cable, and the dock connector as well. If that is all okay, consider getting a new battery, if charging from a wall adapter remains unsuccessful. Also, try to restart your iPod by:
" Press and hold the Sleep/Wake button for a few seconds until the red "slide to power off" slider appears, and then slide the slider.
Press and hold the Sleep/Wake button until the Apple logo appears."
Hope this helps to get you started, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks a lot for your answer I do everything you said but it does not do nothing Hope you can help me
tarafından
Thank you for accepting my answer. Start of with the restart. Then the AC charger and the cable/dock connector. It has to be wall charger. If nothing after that, replace the battery.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 742
