Ana içeriğe geç
A machine of the family of BSH household devices built by the Swiss OEM company Eugster. There are many similarities in its construction with machines by Bosch, Melitta, or Nivona.
Error1 & outlet valve leaks
Hello,
First, thank you for the clear tutorial on supporting the circular economy.
  • My 15-year-old Surpresso is showing "Error 1." Could you help me fix this issue?
  • Since the outlet valve was leaking, I cleaned it and replaced it with a new one. However, I am still experiencing a leak from the outlet valve. What would you recommend?
Thanks,
Tonny
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The Error 1 issue needs to be resolved by Siemens themselves. There's apparently a way to get to the error to see what it's for in the diagnostics menu (Menu -> Diagnostics -> Alarms -> Click on Alarm -> Help) should give you a bit more info but usually it just says to contact Siemans.
As for the leaky valve, if the leak is coming from the valve itself it's most likely that an o-ring isn't sealed properly or has gone bad. You could try getting another o-ring if the valve you bought didn't come from one, or you could try to re-attach the valve so it doesn't leak.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you very much for your support!
The Error 1 because the temperature from external CTN 72° vs. >80°C+ - Boiler R=37Ohms almost 1400w+/230v, thermal protection okay...what should be the probleme since no other regulation on the boiler?
I replaced the drainage valve gaskets, but I’m still getting a significant leak from the valve. 🤔 I’m going to check the assembly again, particularly the drainage that connects to the brewing unit.
tarafından
как решили проблему?
tarafından
Yorum Ekle
Yanıtını ekle
ftonny sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 320
