Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
All USB-C ports functional, except for back left which only draws 5V
Curious to know if anyone can help me diagnose this issue. Three of the USB-C ports draw the correct voltage (around 20V) and can be used to power on and charge the device, but the back left USB-C port is only drawing 5V. I've replaced the USB-C board multiple times but the issue persists even with a new USB-C board installed, indicating a logic board issue. In my experience when there is a fault with the USB-C controller chips on the logic board it causes all the ports to draw 5V. Anybody have any recommendations or tips for diagnosing this issue? Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
@zpl you have checked the port controllers and they checked out ok? Anything "weird" on the connector?
tarafından
Nothing strange with the USB-C board as far as I can tell (and I've tried it with 2 new USB-C boards and got the same issue). I think this is a logic board issue, but I don't know where to start to diagnose which components on the board are faulty. Normally I would suspect the port controller chips, but I've never seen a situation where only one port is stuck at 5V but the other ports work fine and the system is able to boot. Thanks!
tarafından
Could you solve it?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Pop off the port assembly to inspect the contact surfaces, try cleaning using a fresh pink pencil eraser otherwise you may need to replace it MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board
Replace one of the thunderbolt connector boards from the left or right side of your laptop. Görseli
Ürün
$18.99
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Unfortunately the issue persists even with a brand new USB-C board installed (I've tried two new USB-C boards).
tarafından
@zpl - Time to trace out the lines from the logic board connector to the port chip. You could have a break or cold solder joint also inspect the chip with a microscope as sometimes solder beads short things out. The 20V service is driven from the system to the charger. If you have a USB-C power meter in series with a charger you can see this on a healthy port.
tarafından
Thanks Dan! Much appreciated!
tarafından
Yorum Ekle
Yanıtını ekle
Zach sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 36
Her zaman: 205
