ELx800 absorbances directly from the instrument
About biotek ELx800 I only want to read absorbances directly from the instrument via a printer what are the instructions
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@nikolaslavdas this sounds more like a setup question than a repair. I would suggest that you look through the user manual for whatever software your microplate reader is using. Not even sure if you have a printer attached and installed. For that use the operators manual for the ELx800
Bu yanıt yardımcı oldu mu?
Use a plain ASCII-compatible printer. USB-only or modern inkjet/laser printers usually won't work unless using a serial-to-USB converter and driver support.
If you're using BioTek Gen5 or KC4 software on a PC and still want to print, the software must support the hardware printer configuration.
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 202
