Ana içeriğe geç
The Whirlpool WRS588FIHZ is a side-by-side stainless steel refrigerator with a total capacity of 21.7 cu. ft., featuring frameless glass shelves, LED lighting, adjustable gallon door bins, and a factory-installed ice maker. It is equipped with electronic temperature controls, temperature alarm, automatic defrost, and is ADA compliant.
New Auger motor for ice maker
I just replaced my auger motor in my Whirlpool side by side. It worked for like a second then stopped working. It is a brand new auger motor. So any ideas? The cup button works and opens the chute but the new auger motor does not turn.
Update (12/16/24)
I found wires at the bottom of the freezer door that are cut. Could this be my problem with the icemaker not working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @david24164
Please confirm the complete model number of the refrigerator?
There are 3 models beginning with WRS588FIHV i.e. WRS588FIHV00, WRS588FIHV04 & WRS588FIHV06 and they're not all exactly wired the same.
tarafından
@jayeff Hi, my exact model is WRS588FIHZ04. The one I picked was closest to that one on this site. Thank you for your time. David
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @david24164
Unfortunately I cannot find a download online for a WRS588FIHZ04 (Whirlpool part # W11575236) or for that matter a WRS588FIHV06 (part # W11610658) either, so I'm hoping that the tech sheet for a WRS588FIHV00 model uses the same diagnostic procedures to test the components in your model.
Enter the diagnostic mode a shown by the sheet and perform tests #44, #45, #47 & #48 and check the results.
If you find the problem and a different part needs replacing here's the parts list for your model. Locate the wanted part in the list and note the manufacturer's part number that is listed with it. Search online for the part number only, to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hi @david24164
The tech sheet shows a yellow wire going to the ice maker switch but no green/white wire but as I said, this tech sheet is not for your exact model.
Best thing to do is to join, solder and sleeve new wires between each end of the two broken wires (colour for colour) to bridge the break in each wire and check if it then works OK.
tarafından
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 295
