Ana içeriğe geç
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
867 Soru Tümünü görüntüle
Can I replace the port for the lcd screen?
I was replacing the LCD screen and i broke the port plastic pieces and i can't get the lcd's ribbon to stay in place?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
william, unless you have the right tools, like a stereo microscope, an extremely fine soldering iron and a very steady hand, I'd advise against it. You may have to either find someone who can do it for you, as well as trying to find the part. This by itself may be a challenge. I have previously had a board with similar issues. The clip holding the cable in, had broken. I replaced it with a spare clip from an old board. It's a PITA and you still need something with a very good magnification. You can also try to hold the cable down with some Kapton tape, or similar. I'd stay away from any kind of Krazy Glue. If that will not work for you, you may have to replace the board. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
william sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 192
