Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
The original Blackberry Bold smartphone, featuring various improvements from older Blackberry models.
13 Soru Tümünü görüntüle
Why is my blackberry bold 9000 not powering up?
Currently have a blackberry bold that would power up,
there is a steady red light on upper right, it would stay on for 20 seconds then jump to battery mode then jump back to red light. Any options
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Nintendo Switch Kit'leri
Oyuna geri dönmek için hızlı bir düzeltme
Switch Kit'leri Satın Al
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It can be many things, try these steps, one of them will work for you.
1) The most likelly cause is a defective battery, replace the battery with a new one, and this will most likely fix the problem, but if it still doesn't work, try my other solutions.
2) It might be the Battery Connector, take out the battery and check if there is anything wrong with the connector.
3) Restore the OS, Connect your computer to desktop manager and click update.
4) Get a new Blackberry Housing Replacement, and replace it yourself; its easy and simple you just need to watch the youtube clip on the bottom of the page and its very explanitory.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
after699 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 4,718
