Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
859 Soru Tümünü görüntüle
Water damaged, does not turn on.
grandson decided to wash the sand off his ipod under running water. this was two weeks ago, unit should be dry by now. nothing happens when you try to turn it on. one of the original units. any suggestions??
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
wayne, first thing I would do is to disassemble the iPod right down to the logic board. Use this guide for that task. After that clean your logic board with a high grade isopropyl alcohol. Here is a general Wiki. Once your cleaned the board, let it dry. Reassemble the iPod and use a new battery. The lithium battery do not tolerate any water and are unforgiving. Once you have the logic board cleaned and dry, replaced the battery, reevaluate for any further damage. It is possible, that your display as well as your HDD will give you problems. You can check the HDD before reassembly by getting a USB-to-Zif adapter. That would allow you to hook the HDD up as an external drive to your computer. Worst case scenario would be that you would have to replace the logic board, the HDD, the display and the battery, possibly the headphone jack. Sounds like a lot, but it is absolutely doable, and might be ~ $120, depending on the size of the drive. Not a bad deal for an iPod of this quality. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
wayne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 400
