Ana içeriğe geç
Eylül 2020'de piyasaya sürüldü. A3028 model numarasıyla tanımlanır.
Q30's won't turn on
Initially, the headset was switching itself off seconds after being switched on, during use.
Today, however, it didn't turn on anymore.
If I press the power button or the NC button, the blue light comes on. But it won't turn on.
When I plug in the charging cable, the red light comes on.
With the 3.5mm sound cable, the headset also works.
Does anyone know what might be happening and how I can solve it?
Service is not a possibility, because although the headphones are not yet a year old, I bought them through the official Anker website on Aliexpress and they refuse to provide repairs.
Bu iyi bir soru mu?
Puan 2
2 Yorum
How can I bypass the power button, in order to tell if that is the problem or a dead battery? I have a similar problem, but there's no light when the button is pressed, only when the headphones are connected to the charger
tarafından
@tomasdiazaliste You can bypass the power board by using an AUX / 3.5 mm headphone cable.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@ynae sounds like you may have a power issue going on here. It sounds like you're saying it is all working except that it has that power issue. I would consider starting with a new battery first. Check all the wiring and the power switch while you work on that. Use this guide Anker Soundcore Life Q30 değişim pili to work on it. Let us know what you find out.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Can you tell me where I can find the replacement battery? I'll try to follow the tutorial. Thanks for your help.
tarafından
@ynae all of that will depend on where you are. I would wait until you have the old battery. Then use the numbers on that to do a search. That way you know you will get the right battery.
tarafından
Yorum Ekle
Yanıtını ekle
Ynaê sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 74
Her zaman: 2,038
