Ana içeriğe geç
Laptop ku muncung garis vertikal di tengah layarnya
Laptop ku muncul garis vertikal di tengah layarnya bagaimana cara memperbaiki
Translation Indonesian - English
My laptop has a vertical line in the middle of the screen My laptop has a vertical line appearing in the middle of the screen, how do I fix it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@ali42798 we will have to see what this looks like. Post some picture of what your screen shows you, with your Question. Use this guide for that Adding images to an existing question
Commonly, a line on the screen is an error with the screen. For now, connect an external monitor and see if that line disappears. If it does, you know it is your laptops LCD. It may need to be replaced or it could be the display coble or even the display connector.
If that line still shows on the external monitor you know the issue is with your GPU/display cable. Let us know what you find out.
Translation
@ali42798 kita harus lihat seperti apa tampilannya. Kirimkan beberapa gambar yang menunjukkan apa yang ditampilkan layar Anda, dengan Pertanyaan Anda. Gunakan panduan ini untuk itu Adding images to an existing question
Biasanya, garis pada layar merupakan kesalahan pada layar. Untuk saat ini, sambungkan monitor eksternal dan lihat apakah garis itu hilang. Jika hilang, Anda tahu itu LCD laptop Anda. Mungkin perlu diganti atau bisa jadi kabel display atau bahkan konektor display.
Jika garis itu masih muncul pada monitor eksternal, berarti masalahnya ada pada GPU/kabel display Anda. Beri tahu kami apa yang Anda temukan.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Ali sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 23
Her zaman: 23
