Ana içeriğe geç
Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
Touch bar works but no light. What's broken?
A friend has an A2338 whose touch bar works but doesn't light up. I've tried to troubleshoot software issues but the problem persists.
I would like to repair it, since repair shops are hard to come by around here. But I'm unsure were to start, I'm inexperienced all things apple. Can I replace just the touch bar? Or do I need to go with a whole upper case replacement?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Well I will suggest you to Ensuring your MacBook Pro is running the latest version of macOS can fix many Touch Bar issues. So Please check if your macbook is updated to it latest version if it is not updated to the latest version then I will suggest you to update it to its latest version.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I've already gone through several software troubleshooting steps, including updating to the latest version (or verifying that the latest version is installed) without success.
I'm confident it's a hardware issue
tarafından
Yorum Ekle
Sadly the panel its self has likely failed and will need to be replaced. Unlike a LCD panel which has a light source behind it OLED panels emit their own colored light per pixel. Here we have a matrix of lines that run across the panel to supply the signal and needed power for the panel to light up. A good bang or liquid spill can kill the panel. Here’s the guide MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal besides getting a new panel as the cheaper option you might just want to get a new uppercase if your battery is also close to the end of its life as that’s less work and frankly quicker!
Puan 0
Yorum Ekle
Yanıtını ekle
Manuel Luka sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 24
