Ana içeriğe geç
The Peugeot 306 is a compact car of the French manufacturer Peugeot, marketed from 1993 to 2002 (1997 to 2002 for the station wagon and 1994 to 2002 for the cabriolet and the sedan).
Why is my steering shaking at the speed of 90km/hr going up
My steering is vigorously shaking when my car is above 90km/hr
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Balancing must be done
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @starboy19280
A car shaking whilst driving could be due to wheels out of balance or faulty shock absorbers and it can be more noticeable at the higher speeds.
A rough check of the shock absorbers can be done by pressing down hard on one corner of the car and then let it go and then keep repeating this two or three times more in a row to set up a rocking motion in the car.
On the final push let it go and then check if it returns to the normal position with only a single bounce and then stops. If it continues to bounce by itself two or more times the shock absorber on the suspension there, may be faulty.
Do this on every corner of the car.
Another indicator of faulty shock absorbers could be uneven tyre wear
To check if the wheels are balanced, it is best to take the car to a tyre service and get them to check if they are or not.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Starboy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 60
Her zaman: 126
