Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1455 Soru Tümünü görüntüle
Replaced hard-drive. Can't reinstall OS.
Just installed a new hard-drive in a mid-2007 2.16Mhz Macbook. Very easy to replace. Problem encountered in re-installing the OS. Using retail copy of Snow Leopard. Everything going smoothly until I arrive at the "select the disk where you want to install Mac OS X" screen. No HD shows up in the box. HD purchased from iFixit. I know it's not formatted yet. I thought that would happen as I began the OS install process. Am able to click on the disk utility. I see the HD, but I can't click on any options such as repair permissions or verify disk. Does this sound like a simple formatting issue? Also, I didn't have access to the original install disc set. They have been misplaced, that's why I'm using a new Snow Leopard disk. Any help would be appreciated.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
In Disk Utilities go to the Partition tab, choose the number of partitions you like and before you hit OK click on Options and choose GUID partition scheme. You'll should be alright then.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
sacolford sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 975
