Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
rebooting and/or Kernel Panic
Hello to everyone
I'm here today to ask a kind of "advice help suggestion" ... whatever can be of help me to make this MacBook Pro great again
I get this A1398 2015 ( MacBookPro11,4 retina 2.2 IG ) from a friend ...acquaintance actually!
at visual inspections no liquid signs
If I press power button start ( dong and Apple logo appear )... load some OS, but after 10" stops and start to boot again!
A kind of Boot loop ... easy I said !
Well no quite , some times after couple times give back a kernel Panic sign too !
So I decide to open it and check hardware issues ....
The only way to make it boot is to disconnect the touch pad flat ( yes I did replace that already 2 times is not that )
Well is the track pad itself .... No way, I did replace that as well 2 times with some good one working from another a1398 !
Even If I remove the keyboard still give kernel panic and or reboot ......
The only way is something relate to track pad circuit ...I guess
The funny thing is, without the track pad , the laptop start ( very fast spinning fans )
Boot up normally, no as fast as it should be ... but does it
the system has a slight delay in the mouse movement... because under Activity Monitor the process Kernel Task is 500%.... 700%
Of course is searching for something .....
I already replace battery , works fine ... with and with out power supply , yes 85W MagSafe 2
there is nothing I can remove from the logic board to make it works...again ?
I thought you can see the log file from software issues
Some times kernel panic is different
Here:
panic(cpu 4 caller 0xffffff800c7cc473): Kernel trap at 0xffffff800c930f97, type 14=page fault, registers:
CR0: 0x0000000080010033, CR2: 0x0000000000000988, CR3: 0x000000046c6d702f, CR4: 0x00000000001626e0
RAX: 0x0000000000000000, RBX: 0x0000000000000000, RCX: 0x0000000000000000, RDX: 0x0000000001000000
RSP: 0xfffffff2cce63cb0, RBP: 0xfffffff2cce63ef0, RSI: 0xffffff9a20d71af8, RDI: 0x0000000000000000
R8: 0xffffff80359d2580, R9: 0xffffff800d483ffc, R10: 0xffffff808953c030, R11: 0x0000000000004000
R12: 0x0000000000000001, R13: 0xffffff9a20d71a20, R14: 0xffffff9087e907d8, R15: 0xffffff9087e721b8
RFL: 0x0000000000010246, RIP: 0xffffff800c930f97, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0x0000000000000988, Error code: 0x0000000000000002, Fault CPU: 0x4, PL: 0, VF: 0
Panicked task 0xffffff95544d8060: 4 threads: pid 91: DumpPanic
Backtrace (CPU 4), panicked thread: 0xffffff9087e90000, Frame : Return Address
0xfffffff2cce63660 : 0xffffff800c679a3d
0xfffffff2cce636b0 : 0xffffff800c7dcd16
0xfffffff2cce636f0 : 0xffffff800c7cc083
0xfffffff2cce63740 : 0xffffff800c619a90
0xfffffff2cce63760 : 0xffffff800c679e0d
0xfffffff2cce63880 : 0xffffff800c6795c6
0xfffffff2cce638e0 : 0xffffff800cf14e33
0xfffffff2cce639d0 : 0xffffff800c7cc473
0xfffffff2cce63b50 : 0xffffff800c7cc156
0xfffffff2cce63ba0 : 0xffffff800c619a90
0xfffffff2cce63bc0 : 0xffffff800c930f97
0xfffffff2cce63ef0 : 0xffffff800c931987
0xfffffff2cce63f40 : 0xffffff800cd86f0b
0xfffffff2cce63fa0 : 0xffffff800c61a256
Process name corresponding to current thread (0xffffff9087e90000): DumpPanic
Mac OS version:
21H1123
Or here a new one :
panic(cpu 4 caller 0xffffff801003603e): Kernel stack memory corruption detected @stack_protector.c:37
Panicked task 0xffffff86948b6380: 2 threads: pid 91: DumpPanic
Backtrace (CPU 4), panicked thread: 0xffffff99c5d8a540, Frame : Return Address
0xffffffffffd4b920 : 0xffffff8010079a3d
0xffffffffffd4b970 : 0xffffff80101dcd16
0xffffffffffd4b9b0 : 0xffffff80101cc083
0xffffffffffd4ba00 : 0xffffff8010019a90
0xffffffffffd4ba20 : 0xffffff8010079e0d
0xffffffffffd4bb40 : 0xffffff80100795c6
0xffffffffffd4bba0 : 0xffffff8010914e33
0xffffffffffd4bc90 : 0xffffff801003603e
0xffffffffffd4bca0 : 0xffffff8010120119
0xffffffffffd4bef0 : 0xffffff80101cc7c9
0xffffffffffd4bfa0 : 0xffffff801001999f
Process name corresponding to current thread (0xffffff99c5d8a540): DumpPanic
Mac OS version:
21H1123
My question now is , how can be memory issue if it is working with no track pad ?
And even so , why only kernel panic about memory ....?
PS: I already replaced the NVMe already same issues .... H. Sierra , Monterey and Sonoma !
Any suggestion will be highly appreciated , thank you .
Ciao
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
A panic that you are encountering with the trackpad connected maybe a RAM issue, not in the way you're thinking! The memory stack is driven by a set load order of the OS and the needed drivers. So when the trackpad is not installed you are leaving a void so that could be why it works. That would be a bad chip or more likely a cold solder joint on one of RAM chips or the PCH chip the RAM connects to.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hello there , thank you so much to take your time to explain this matter !
Wow I did not think of that make sense . Well ,now I think I have a very hard job to discover where the issue is locate ….
Have a great day thank you again , cheers
tarafından
Yorum Ekle
Yanıtını ekle
analfabetagoloso sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 107
