Ana içeriğe geç
Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
Touch ID not working after MacBook reassemble
I tore down my Macbook Pro to clean the dust off.
During the disassembly process, I didn't touch the Touch ID connector. I just removed the motherboard to replace the thermal paste and clean the fan.
After I reassembled it, everything is great, except the Touch ID was not working. But the power button is good.
Any ideas about it?
Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The TouchID cable and the connector interface at the logic board is where you need to check. The cable could have a tear severing one of the lines, at the connector a pin connection could be damaged either by being a bit hard prying it off or pressing on it without aligning it properly before pressing it on with a light touch.
Hopefully you can fix the damage which is still not easy! If you can't repair your options are only replacing the logic board as the button ID key is perm bonded to the given logic board (you can't replace it on its own).
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Lynn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 94
