Ana içeriğe geç
Repair for LED, incandescent, and other handheld electric light sources.
22 Soru Tümünü görüntüle
Where can I get a battery holder for my Rayz LED Flashlight?
The only thing broken on this flashlight is the cheap-o metal part that makes contact with the battery. There is a 3-AAA battery holder the inserts inside the little flashlight.
The switch is a pushbutton on the bottom
I just need to replace the 3-AAA battery holder.
Where is a good source for these parts?
Thanks
Frank
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I couldn't find any replacements parts for this but I looked at mine. If you're talking about the plate that makes contact with the spring, consider replacing with a copper penny (pre 1982) and some solder. Maybe a silver dime (pre 1964) if the penny is to large.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorumlar:
tarafından
Yorum Ekle
If the 3AAA battery holder is broken you can get a replacement from Dorcy. http://www.dorcydirect.com/c-19-flashlig...[pagenum=2*Sort=4*ava=0]
You will have to figure out which holder fits your flashlight, as they are not all the same. If your holder is the standard 3AAA holder with no "special" features I would look at 41-8046.
Good luck,
Joe
Puan 0
Yorumlar:
I have one that has the same connectors as the lightbulb section and unable to remove either does this mean its a rechargeable and if so where can I find the charging base and the screw on bottom battery holder
tarafından
Its a rayz brand btw
tarafından
Yorum Ekle
Yanıtını ekle
040304 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 4
Son 30 Gün: 15
Her zaman: 3,077
