Ana içeriğe geç
iPhone 11 WLAN OK; Bluetooth very bad signal
As mentioned above my Iphone 11 appears to have extremely bad bluetooth signal. I cant move the phone before the signal cuts off. Managed to connect it to my car but its got to stay in my center console and i cant move it anyhow or it cuts off.. Airpods dont connect at all. WLAN however is totally fine and the signal is pristine on further distances.
Any idea on what this might be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
Has anything happened to the phone recently such as damage or liquid exposure? How long has it been like this?
tarafından
There was liquid detected in my lightning port once, but that was because of the increased humidity in winter. Other than that raindrops on the screen but never fully dropped and submerged somewhere. Also got the phone from a refurbishing shop, so they probably made some fixes to the phone (display, lightling and so on). It has been line this pretty much since i required bluetooth for my new airpods or car radio, so i assume all time..
tarafından
Sometimes a drop from not more than max half a metre. Cracks on the back of my phone show it
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Okay, after a bit of research, it appears your phone has a dedicated antenna for the bluetooth. I'm theorizing that it either got damaged in the refurb process or as a result of a drop; either one is quite possible. Here's the part.
iPhone 11 Bluetooth Antenna
Finding a guide showing how to replace it is a whole different subject. There doesn't seem to be a guide for just that, but I did locate a guide to replacing the power button/flash/upper microphone assembly that shows the removal of that bluetooth antenna as part of the process.
Manuales / Apple iPhone 11 / Power button, flash and top microphone - Nadie Me Llama Gallina
Note that the guide is written in Spanish, but if you use it with a browser like Chrome that does translation, it works quite well.
Anyway, it looks to me as though you can follow the guide through Step 5, skip Step 6 and remove the antenna as shown in Step 7. Check carefully as I'm not positive about skipping Step 6, but it doesn't look like there's anything to removing the wifi antenna that's needed in order to access the bluetooth antenna.
As you work, take lots of pictures and once you're done you can use them to create your very own iFixit guide to that repair for those who come after you with the same problem. It's easy, fun and will earn the appreciation of the repair community.
Create a new Guide - iFixit
Good luck, and let us know how it all turns out for you!
Replace a Bluetooth antenna compatible with the A2111, A2221, and A2223 model iPhone 11 smartphone. Fix unreliable connectivity Bluetooth devices. Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks for the reply. Ill give it a try!
tarafından
Yorum Ekle
Yanıtını ekle
Zen _ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 262
