How to enter service mode and test water valve to ice maker?
How do you get this model into service mode? it does not have the usual Freezer up/down buttons.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here's the service data sheet for the refrigerator.
There is no specific diagnostic test that checks the ice maker water valve per se.
There is a manual ice maker water fill test you could try, plus a wiring diagram that may help.
Not sure but I think that the test button may be located in the tiny hole in the yellow plastic to the right of the switch - see image.
You may need a pen or small screwdriver to push to operate it
9click on image)
Bu yanıt yardımcı oldu mu?
Thank you, that is what I've been looking for, but failing with the Frigidaire model #.
Where is the icemaker power test button though?
My ice maker has a black power on /off rocker switch on the bottom of it. Do you have to remove the cover on that assembly?
Ice maker bottom view pic added to original question
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 330
1 Yorum
[image|3731203]
gregmiddleton tarafından
